No, you can’t. The tie rod adjustments won’t have any desired impact on the camber and caster settings.“…..Can I get it "good enough" with just tie rod adjustments??
You say you can put in a thin shim stack. Only by trial and error will you find out if it’s going to work out.
Offhand, I doubt that a shim stack under 5/16” - 3/8” is going to be satisfactory. But every car is going to be a little different.
Z
