I could use some help on this one. I am putting a 351 W out of a 70 mach in a 66. most of it was disassembled when I got it. the problem is the alt. pulley is not lining up wit the other pulleys. This has the triangle shaped bracket on the side of the head that the top alt. bolt mounts to. (also, how do you fit the dipstick tube in with this bracket on the head?) the pulley grove is off line by about the thickness of the bracket ( about 3/8"). I need this bracket on the side of the head to line up with the upper alt. bracket. What gives? what am I doing wrong. I blew it and went to a show yesterday and forgot to look at other cars. Thanks for any help. Joe
r u using a 289/302's brackets?
they may not line up..the deck height is different
The brackets all came with the windsor. The lower alt. bracket has a 70 part # . Everything seems to fit O K except for the lining up problem.. Thanks for your help. Joe
