Ok, finally got everything wired up. Battery is charging at 14+ , and the amp meter is pegging when at RPM. I don't believe this is correct, from what I have read the amp meter hardly every moves on a 1967. It also started to smoke at the starter relay when trying to start. I did not change Volt regulator when I put the new Alt in. Could this be it? Next question my brake light stays on all the time. Thanks :wall:
