mariofenu said:
I am runnig a GW stage 3 kit. I am uncertain of the front spring rate, as I know the current kit they offer has been modifed a little since I purchased 3 years ago. For ex. they no longer supply Cure ride shocks in the rear, instead now QA-1 adjustables. It's possible they switched the front spring that's in the kit.
I am seeing from all of your comments that my Koni's may not be THE problem I am unhappy with. I will first try turning up their damping rate a little, and then maybe experiment with a stiffer spring.
What front suspension setup are all of you running with your Koni's?
The front springs on your stage 3 are 540#/in.
They are an off the shelf Moog that actually
fit another year Mustang. This would be their
S-23 spring and this is what you have unless
you have something unusual, like a big block,
351W with iron heads or use the car only for
the track.
The swap to QA-1 in the rear was made purely
for volume and ease of obtaining parts- the
Cure Ride shocks are still manufactured but
are a PITA to get.
You never did say exactly what you are unhappy
with in terms of the front Konis.....
I've got the second car they put together back
in 1986- 1966 GT, Koni double adjustable front,
Cure Ride rear, full Stage III Global West plus
some stuff they don't sell. I've retired it as
far as open track is concerned but with only
240 rear wheel horsepower, it would usually be
the 3rd or 4th quickest and I drove it to and
from the track.
I'm happy to help you if you elaborate on your situation.....
ex-Global West GM
1991-1994
