a few quick questions -
The battery ground goes to the engine or the body?
There's a pole labeled "sta" on the back of my alternator - to what other part of my car should this connect. Forget the wiring harness... If I were to run a wire straight from "sta" to the next component, where would it be?
Thanks,
Matt K.
The battery ground should go to the block.....it s a good idea to have a good ground strap from the block to the car, BTW.
I dont believe the stator is hooked up on many mustangs IIRC.
