1 - 9 of 9 Posts
I am build a car too race. I seen the alum. heads and all , but I want too stay with ford parts.
chris
aluminum for me all the way!
the biggest disadvantage of aluminum heads is price. Airflow=power, lighter weight = power and they also let you get away with a higher compression ratio.
The biggest advantage of steel heads is that you can stick the do not touch magnets to them at shows. You also don't have a problem with bolts and spark plugs wanting to weld themselves in place.
hell with the shows.
I just feel it's cheating. not that there bad, but I just want too stay ford all the way!
chris
if you REALLLLLLY want to stay ford, build a clevor
btw, ford doesnt build the carbs/slicks/etc etc
I built my own Ford heads. (68 302 4-V 54cc) Have about $750 in them and I did my own port/polishing. But I cheated; I put chevy valves in them!(1.94/1.60)
Ford sells aluminum small block heads.
Get yourself a 2002 SVO parts catalog and check out all the performance parts Ford sells.
The GT-40X heads are supposed to flow pretty good
Discussion Starter #9
I wound up doing my own heads. 351 port & polished shaved. over size vavules (not chey).
chris
1 - 9 of 9 Posts
