81 - 100 of 110 Posts
Ugh, that stinks. Keep at it, it will be worth it once it’s sorted out. One time, I had a rim show up bent, had to go through the whole process on the return.
With my latest wheels, the stock lugs were too big, so had to get a new set via Amazon prime!
1965 Coupe C-Code
Discussion Starter · #82 ·
I've ordered all four wheels from Summit. Cost me an extra $75 in shipping alone in my quest to save money by buying from different suppliers. I call that a stupid tax.
Summit has been great on the customer service end although these days sending out the wrong parts should be nearly impossible as product should be scanned several times before going out the door.
Let's see how JEGS is about returning the bad wheel and the good one.
1965 Coupe C-Code
Discussion Starter · #85 ·
Got the wheels from Summit today. They look perfect. I’m not sure what the deal is with the Jegs wheels but they are different. Different packaging and different quality. And not better. Jegs stuff is going back.
Test fit the front. Clearance at the upper arm and tie rod. Will need to wait to get tires on to check final fit but I’m confident.
I can certainly see why @aakrusen tried the spacers on the front. These wheels with 0 offset fit inside the wheel well. Now I’m going to try to lower the car quite a bit and maybe that will be a good thing. Or maybe I’ll need some spacers too.
I thinking about the extended studs so spacers won’t be an issue.
Anyways tires on tomorrow and then we’ll see where things actually fit.
Also getting different lug nuts tomorrow too.
Tire Wheel Automotive tire Locking hubs Vehicle brake
Shipping box Motor vehicle Automotive tail & brake light Tread Road surface
Tire Wheel Bicycle wheel Bicycle tire Crankset
Rectangle Font Linens Toy Carmine
Automotive tire Motor vehicle Automotive lighting Vehicle Fender
Photograph Light Black Automotive tire Hood
Wheel Tire Car Vehicle Automotive tire
1965 Coupe C-Code
Discussion Starter · #91 ·
Tire Wheel Sky Car Vehicle
Wheel Tire Sky Vehicle Car
Wheel Tire Vehicle Sky Cloud
Tire Wheel Automotive tire Hood Synthetic rubber
I’m not convinced the stance is perfect but it’s close.
The tires are 225/50-16 Continental Extreme Contact Sports. The tire guy says they are decent autocross tires and not bad on the street as long as you avoid the snow. I’m good there.
So far no rubbing at all. Didn’t roll the fenders. I’m tempted to drop the fronts another 1/2 or so. But also tempted to raise the upper arm to the stock positions. But that’s a separate thread.
They look great, it would seem to be a move in the wrong direction to move the upper arm back to stock and then autocross. kip
It looks great! Those are a slam dunk. I have the exact same tires on mine and I think they look awesome.
Only difference is I have the 205’s on my front cause the 16x8 4.89 bs had me rubbing the upper ball joint with the 225’s.
Oops!, may have forgotten that:whistle: kip
No caps or flat caps, not a fan of those.
Reactions: 68Ghost
