This listing is for an AMK Products Bolt Kit that is used for a 70 or 71 351C 4V. The original AMK Part Number for this kit is D0OE-1176. The current online list shows the newer Part Number for it is 70O-351C4. This kit contains 22 AMK parts bags (unopened). This Kit supplies the following bolts/nuts/washers/studs: Water Pump, Air Cleaner Wing Nut, Distributor Hold Down, Oil Pan, Carburetor Studs & Nuts (w/o spacer), Fuel Pump, Exhaust Manifolds "RAMPLOK" Bolt Set, Air Cleaner Snorkel, Air Cleaner Heat Shroud, Distributor Vac. Unit, Dist. Points & Condenser, Air Cleaner Support Bracket, Crank Pulley, Crankshaft Damper, Intake Manifold>Engine, Water Neck, Timing Cover, Engine Block Drain Plugs, Starter, Engine Lift Hooks, Engine Fan > Water Pump, Aluminum Valve Cover Bolts. These are the correct bolts for use in reassembling your 70 or 71 351C. Price is $85.00 shipped to the lower 48 States. No P.O. Box Numbers please. Please contact me with any questions. Thanks for looking.
Matt
