1 - 9 of 9 Posts
I've searched and read many threads but still struggling with my wheel and tire option
I saw the fitment guide from Halibrand. Very helpful
My challenge is I want a Torq Thrust looking wheel in black spokes 15" and can't seem to find any front wheel with the right back space
I'm wondering if the following will work and if anyone sees any issue
Back = TTD 15x8 4.5 BS running 225/60 tires
Front = TTD 15x6 3.66 BS plus a 1/4 spacer running 205/60 tires
Stock suspension
PS can I sneak a 235/60 on the back?
I have the 15X6, 3.66" BS TTD on the front of my '65 with 215/70R15 tires. Shelby drop, rolled fender lips and Granada discs. No rubbing. The 205/60 tire is going to be pretty small.
Thanks for the info. If I can't find 7" rims I like with the right backspacing, will a 6" with a BS of 3.66" and a 1/4" spacer be a good option for the fronts?
The 15 x 7 on Husk's car are 3.75 bs less than ideal and he makes them work. 15 x7x4.25 is ideal . I ran some 15x7x4.50 Explorer wheels for a while with 225/60/15 but I had to " clearance" the UCA around the ball joint
I was under the impression that a 7" with a BS of 3.75 would require rolling the front fenders. Is that incorrect?
Not if you use 215’s in the front. 225’s will work in the rear...both with 3.75” BS. 225’s can work up front, but they will rub while turning and dipping if you don’t roll the front fenders.
Discussion Starter #9
^^ good to know thanks
So sounds like a 15x7 (3.75 bs) in the front with a 215/60 and a 15x8 (4.5 bs) in the rear with a 225/60 will work without any mods.
Will a 235 fit in the rear or am I pushing my luck?
Fitting wheels to my S197 sure was more straight forward....
1 - 9 of 9 Posts
