I don't really know how to explain this but I will try.
I took my 65 to my mechanic among other things because the amp meter would not move and it slowly discharged the battery when parked. The amp meter would move when the fog lights were turned on.
We put a new voltage regulator (vr) on but it was not the problem. When we connected the negative cable it would spark and the vr would click. We found a cable from the solenoid to the alternator that the previous owner had installed. When we took it off there was no more clicking of the vr. But the car was then only running off the battery. Without the battery hooked up it would stall. In my mind this jumper cable was a way to bypass the correct path. But it is obviously not correct because when it is hooked up I have the vr clicking and the discharge when sitting. I might add that it does charge when running and the jumper cable it hooked up but it does not reflect that on the ammeter unless the fog lights are on.
Also, as if things aren't bad enough, there are two wires he added. One hooked up to the alternator and one hooked up to the solenoid running to the ammeter.
I know this is a mess. Any help that y'all can give will certainly help.
