Performance wise, what are the advantages of a C6 over a C4.
What are they best suited to . IE engine size and mods .
Is a C6 better than a C 4 or does it depend on the application ?
PLAY NICE !!!
http://albums.photopoint.com/j/View?u=1584152&a=12055089&p=46927243&Sequence=0&res=high.jpg
Gone but never forgetten
Depends on the application. The C6 is a stronger tranny, thus the reason all the trucks get them. That strength comes with a severe penalty, though ... weight, lots of weight. The C4 will perform better, but the a stock C6 will withstand more abuse and HP than a stock C4.
http://www.classic-mustang.net/john66/mustang/pics/66fsides2.jpg
So a C6 is only for big horse power stuff. It would be overkill on a standard car
C4 is fine for regular use ?
PLAY NICE !!!
http://albums.photopoint.com/j/View?u=1584152&a=12055089&p=46927230&Sequence=0&res=high.jpg
I would recommend the C4 ... easy to work on, plenty of aftermarket parts, plenty of performance for most applications.
With a 289/302 and 351W, a C4 is fine in most applications...theoretically that should extend to the 335 series engines but so few people build mild ones that I always recommend a C6 or Powerglide with those....Obviously, FE and 385 series engines should use a C6 because they make such a large amount of torqe at low rpms...
Granted, this is general advice....
The most HP I've run through a C4 in a racing application is around 450 flexplate HP.....I know of others who have run more but have no practical experience...
Remember, this is with 8" converters and drag slicks in a pure racing environment...
My trans is a blueprinted stocker with updated friction materials; no aftermarket parts whatsoever, other than a shift kit. The converter has been everything from a 4500rpm stall 8" to the current 2800rpm stall 10" street converter...
Hey, have fun! *G*
Pat
I would agree with all, Johnpro specially. C4 lighter, easiest to work, parts, numerous applications. IMHO, quicker on short distance because of weight.
69 Coupe 302, 4 speed, primer red (for that "saving my $ for a real paint job !" look)
66 Coupe, Sauterne Gold , 200 (aka goose sh** green) rust bucket
