·Guest
Have you considered the fuel pump as a source of the tapping?
No. I can clearly hear it emanating from the block. Whats a bad fuel pump sound like?
Hmm. Try this, do you have a test lamp? Disconnect the + side of the battery. Connect one end of the test lamp to the battery cable and the other end to the positive post. Does the lamp light? If so, something is shorting out. Usually it's a door light or interior light that gets stuck on. You can pull fuses again until the light goes out, there's your trouble.
No lamp, but I have a setup with a buzzer that goes when the circuit is closed. I pulled the +cable offthe battery and used the buzzer to complete the circuit, and it buzzed. So that means a drain from what Im told. So I went and pulled each of my 5 fuzes one by one looking for the culprit, but the buzzer buzzed for each fuze I took out. What gives?
Also, I replaced a bad bulb from under my dash. But that couldnt cause such a powerful drain could it? Ppl said maybe volt. regulator, or alternator. Well, my alt. is new. Ill get it checked at the local shop. Is there a way to test a voltage regulator? I bought a bluestreak one bout a year and change ago.
About the tapping, pulling plugs does not affect the tapping.
What is piston slap? Is that what is caused by a bad wrist? pin? I ppulled my oil pan, they looked fine. Couldnt get in there to test them at all, or know a way in which to do so.
About cookies, I've dumped all my cookies, same problem, must leech other peoples computers to login GRRRRR!!!!\
Thanks for the help all, -E.
