Ok, got some hose and spring clamps and went to work when I got home.
1. First pic is the before, closeup. I just want to say I am not responsible for this messed up engine bay. It is as found after purchase. Hose under the air cleaner is the PCV hose. Next one down is a giant loop of fuel line that's getting replaced next. Third hose is a giant loop back on the heater. Also to get sorted here shortly.
2. Installed. Took all of 5 minutes because I was taking pictures, lol. It is a hair short on the front to back run and on the riser to the carb. Have noted this in the build measurements (+1/4").
3. Installed again, different angle which shows the 45 bend up to the PCV elbow. I can run it all the way flat too and rise up at the end. Was just going for minimal material and lowest restriction.
Let me know what you think. It sits in the valley well. I might add an O-ring or two just to keep it off the valve cover.
