I'm trying to get the speedo gear back into the transmission. I've tried jiggling, moving the gear slightly and re-inserting, and moving the drive shaft while in neutral; all to no avail. Is there a trick to getting this thing re-engaged?
Also, the new cable has a plug (just behind the speedo gear) that slips into the transmission. It appears to have a slot that an o-ring would fit into nicely. Should there be an o-ring in this groove? The old cable didn't have one; but then we had lots of fluid on the outside of the transmission, also.
Cable is identical to the one I took off, and the speedo gear is the one I took off the old cable. I just attached it to the new cable. I will run down an o-ring at the local hardware store. I was just hoping there was something I was missing on trying to get the gear re-engaged.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Vintage Mustang Forums
