No reply for my last post, so I'll try again:
I'm attempting to assemble my deluxe wheel. Here is the exploded view from the illustrated manual, so you can play along at home.
What I'm finding is that when I install the three screws without the springs (52792-S) through the plate on the front of the wheel (13A848), through the collar (3491) and into the outer horn ring (13A890/13A808), there is not enough separation between the outer and inner horn ring. In other words, they are in constant contact.
What am I doing wrong here? I've thought about putting some washers behind the 13A848 plate, thereby slightly pushing back the collar and outer horn ring. Do you think that would work? Even if it does, that can't possibly be what Ford had in mind....
Steve
Steve
