Good rule of thumb is 30-50 hp at 6000 rpm....remember, since an automatic is just a big hydraulic pump with a bunch of stuff rotating behind it, the HP requirement depends on RPM and pressures required internally.
As an example, the C4 in my
race car, which has been blueprinted and runs low friction thrust washers, might actually have a higher HP loss, since it has been altered to produce a higher line pressure (for more clamping force), which takes more HP to produce.
I wouldn't worry to much about the losses in a AOD...the positives far outweigh the negatives, IME experiences here on the VMF and with friends who've done the swap.....Since the AOD has more stuff inside for the extra gear, it's a little heavier than a C4 and, if it has a lock-up converter, that'll add some weight too...still a pretty light trans
