You will need to get the flexplate, block plate, gravel shield and attaching hardware from the donor car. The tv cable should stay with the tranny, watch how it comes apart at the throttle body so you know how to re-install it onto yours. The plastic grommet on the throttle body that the cable will attach to will probably break if you try to remove it, they are about $5 at the local Ford dealer. You should be able to use your existing computer, you may have a idle problem in drive and if you do you may have to find a automatic ecu. Get the driveshaft, crossmember, speedo cable adapter, shifter and cable from the donor car if you can. If you cannot get the shifter I may still have the automatic shifter from the 91 GT that I removed my aod from. Have fun
