The L2482F is a good piston. Forged and not cast. Compression height is 1.605 inches, giving a deck clearance with an 8.206 inch block and a 289 rotating assembly of .011 inches. The valve relief volume is 2.7cc which is only .7cc more than a stock "A" code piston. My only concern would be what head gasket is being used. My preference would be to use one with less than .040 inch compressed thickness... I'd probably go with an .027 or .030 inch thickness to keep quench as close to .040 inch as possible.
As for the $3100 price tag.... Seems like a good price but the flow numbers on the heads aren't anything special and, especially the exhaust, are killed by AFR 165's. With the combo shown, a .040 inch head gasket (common size) and stock deck height, expect a static compression ratio of 9.15:1. I'd like to see something a half-point (or more) higher... My other concern is the 2.02 inch intake valve and whether, or not, the builder has checked piston-to-valve clearance... I think, for 25-30% more, you could find a long block that not only has similar performance but also a roller lifter valvetrain and a warranty.
