As the title suggests, I'm trying to decide which way to go. The floors were shot due to rust, previous crappy repair, and accident damage. The passenger side front frame rail/floor support had also been pushed way out of position which wrinkled the tunnel. I'm trying to get motivated to get back to work on this thing and looking for some input as to which would be the "best" way to go. I have replaced the firewall, front frame rails, and patched the cowl side panels. I still need to get the upper/lower cowl and core support back on, but then will be ready to work my way towards the rear. I already have "full length" floor pans for both sides and trunk drop offs. The transition pan is in good shape, but I plan on replacing (don't have yet) the rear frame rails (most likely torque boxes, too) and the rear trunk brace.
I hammered the tunnel back into shape the best I could, but would I be time ahead to just get the one piece floor, or will it take a lot of persuading to get it to fit? If I'm going to end up replacing most of the back half, should I just get the assembly? If I go assembly, I'd probably remove the floor supports from it since I already have them installed on my frame rails, and cut/patch into the existing inner rockers which only need minor repairs but they're quite a bit more $$$ than just the one piece floor pan. Even though the one piece are not horribly expensive, I already have the full length floor pans which will serve my purpose, but it'll be a lot of welding and grinding.
I'm stuck on this merry-go-round... someone needs to push me off.
