The AC is pulling into a vacuum and freezing at the expansion valve. Whats the problem / solution? It's really hot down here in Florida!
Proud Owner of a 1969 Mach 1
Might be overcharged. Get a set of A/C lines and monitor the pressures. high side of compressor should be around 175. Low side should be around 20? this is from memory, so it may not be accurate. I will know tomorrow when I get my system re-charged (presently evacuated).
http://albums.photopoint.com/j/View?u=1571478&a=12535662&p=46267978&Sequence=1.jpg
If the low side is a vacuum (Negative pressure) and ice forms around the expansion valve, either the expansion valve is malfunctioning or a restriction (trash) in the valve. If there is a sand like substance in the valve, check for a perforated dessicant bag in the filter/dryer.
Required tools for operating a Vintage Mustang:
1. Duct Tape
2. J.B. Weld
3. B.F.H. (Big Fat Hammer)
4. VINTAGE MUSTANG FORUMS II
View Album Here: http://albums.photopoint.com/j/AlbumIndex?u=1616948&a=12352157
Sounds like a blockage. Put a set of guages on it and check.
Vintage Burgundy 1966 Mustang GT Fastback (Midlife's younger brother)
MCA member #46447
