I saw you replied to my post about tachs, but thought I would repost since my previous one was already pretty well-buried. Rich says to tap into a red/green wire at the fuse block, and a red/green wire at the steering column. The wire at the steering column is the resistance wire, what is the one at the fuse block? I assumed it was just a 12V switched source, am I wrong? When he says "tap" does he mean to cut the wire completely, or leave the wire intact, just hooking the new tach line to it? Thanks alot, I appricate the help!
-Jason
'72 Mach 1 || '90 Talon TSi AWD
http://nosaj122081.tripod.com/parade3.jpg
"Thats not a leak, my car's marking its territory!"
"If you've done it, it ain't braggin'." -Roy Rogers
lol no luck yet huh jason. keep tryin man. u will get it sooner or later.
~Chris
San Antonio, Tx
66 coupe 289
70 fastback done by may/graduation...hopefully
Tap in this case means to splice the new wire into the existing wire.
http://clubs.hemmings.com/baymustang/platesmall.jpgLet me check your shorts! My multimeter is just a-waiting! Formerly known as Midlife in the old VMF.
King of the Old Farts *struts*
Discussion Starter · #4 ·
THANKS!!!! I wasn't doing that, I'll have to give it a try! I was cutting, not adding!
-Jason
The tachometer lead is in series with your ignition coil, unlike EVERY other car manufacturer. So if your car starts and runs with the tach disconnected, something isn't right. Good luck.
Jim Gates
72 Mach 1 - 460, C6
65 Olds 4-4-2, 400 ci, 4-sp
71 Dart Swinger 340 - Project in the queue
