1 - 2 of 2 Posts
4
Hi. I'm replacing my Holley 1850 with an Autolite 4100 1.08 on a pretty much stock '65 A-Code (4sp manual), 2" exhaust.
Hopefully someone in the area can shed some light on what general jetting settings etc. works best?:pirate:
Much appreciated as I'd rather ask now rathen than after its on with my luck.
IF the 4100 that you are installing is all stock and original with no alterations it should be perfect right out of the box for your engine.
Just install and set your air/fuel mixture screws and idle speed and choke and you'll be fine.
1 - 2 of 2 Posts
