1 - 9 of 9 Posts
My Auto Transmission "T" Handle is loose and rotates. I tried tightening the set screw at the base of the handle, but it will not tighten up. It feels like it will tighten, then just as it gets a little tighter, it suddenly becomes loose again. Do I need to replace the set screw?
Any thoughts?
Thanks,
Mordi
Gone but never forgetten
And you should get a t-lock from Hal to go with your new set screw ::
Whisperer (Hal) and his company Vintage-Automotive.com sells a very trick t-handle that you can lock so the car can't be taken out of gear without the key. It's a nice security feature, that I have in my 3 running Mustangs.
I had the same problem with mine. I think the threads in the handle get stripped. I even bought a new, longer set screw which worked exactly 2.8 seconds (until I used the shifter). So I followed Johnpro's advice and sent a check off to Hal for the T-lok.
Frank
johnpro,
That t-lok looks pretty nifty!
How do you install it?
I wonder if it includes a new set screw? ::
Mordi
Discussion Starter #9
Johnpro,
Ok - I'm going to order one.
Thanks,
Mordi
1 - 9 of 9 Posts
