I‘m getting ready to replace the bearing s and seals on my 68 8” axle.
Axle is apart, blasted, painted, and the new Traction loc with 3.4 gears is ready to go together. Just need to install the new bearings. I have a few questions there.
1. The service manual and all the videos I have watched say to cut off or punch the spacer so it can be removed before pressing off the bearing, but on install of the new ones the spacer is pressed on with the bearing. Anyone know why you just don’t press them off together? Seems like extra work for nothing, but Ford obviously had a reason.
2. Should I use oil or other lubricant on the axle before pressing on the new bearing so it goes on smoothly?
3. How do I know when it is fully on in the right position? Is there some type of positive stop? I don’t want to press too hard and damage it, but I want to make sure it is fully on too.
4. Should I use sealant on the gaskets either side of the backing plate or install them dry?
5. What is the preferred lubricant for a traction loc these days?
6. 8 & 9“ rears sent me friction modifier For the traction loc, Do I use the full bottle?
