1 - 10 of 10 Posts
bnichols04 said:
is the axle tube diameter 3"? it is out of a 68 Mustang. Was there more than 1 diameter on the 8" axles?
No. The '68 axle housing tube diameter is 2¾".
The '65/'66 Mustang axle housing tube diameter (in the area where the U-bolts attach) is right at 2-3/8".
'57-'59 Ford big car, Ranchero/station wagon 9-inch rear tube diameter is 3".
'77-'80 Lincoln Versailles (and '75-'80 Granada/Monarch) 9-inch disc brake housing tubes are 3".
75-'80 8-inch rear end tube diameter is 2¾"
75-'80 Granada/Monarch 9-inch drum brake rear end housing tubes are 2¾.
Wow, seriously? The u-bolts that LMM gave me for my suspension install are 2 7/8, or 3".. I think maybe 2 7/8", but they are still too big for my 8.8 housing.. I imagine they would be swimming on my 68 8" then!
Johnny K.,
I found for the Fox swap that I needed 2-7/8" U-bolts. I see a lot of guys use the 3", but like you found, that is too loose. Your local Napa should have the correct U-bolts if you can use a 7/16" diameter bolt, or a spring shop can fab up a set of 1/2" diameter bolts real quick for you.
Well they might be 2 7/8, but they still seem pretty loose? What did you do about the spring/shock plates? Just kind of bend the springs together and stick them through? Is 7/16 a bad idea?
that is what i had to do. I have the 8" out of a 68 and installed in my 65 but the shock plate was for a 65 and the lowering blocks w/ u bolts were for a 68 so i had to squeeze the bolts together to get them to fit through the shock plate.
I'm running Caltracs which have their own slotted plate, so the bolts worked fine, with grade 8 washers. My experience is that 7/16" is good for around 300lbs/ft torque when installed properly. Above that, I'd suggest 1/2".
YMMV
edit****
If your U-bolts were supplied by a Mustang shop, they are not correct for the Fox rear end. I went through this with Cobra Automotive :thumbsdown: Those guys can not think outside the box. Finally went to Napa and got what I needed.
Well what I find funny is my U-bolts came from Laurel mountain.. in a standard suspension kit (Nobody knew I was planning an 8.8. Not even me), yet the u-bolts they gave me seem to be about 2-7/8.. But you guys are saying for a 67-68, I should have 2 3/4? So does this mean they gave me the wrong ones (But they might end up actually working for the 8.8, but WOULDN'T work for an 8" like they thought I should have?).
Which shock plate to use
I am new to vintage Mustangs and just purchased a 1965 coupe. I appear to have a similar situation where the axle appears to be 2 3/4". The previous owner bent the U bolt to fit into the smaller spacing of the shock plate (appears to be 2 3/8"). I plan to replace the leaf springs and U bolts. Should I use a 1968 shock plate to match the dimensions or bend the new U bolts. If I went to the 1968 shock plate, would that impact the shocks or leaf spring I should get?
Thanks.
1 - 10 of 10 Posts
