Hi Guys,
I'm experiencing some issues with my 289 Mustang and need some wisdom. I'm having trouble with vacuum and am experiencing a slight backfire at idle once in a while. I thought it may be bad plugs so I just replaced all of them with new plugs and gapped them at .45. Here is a list of my setup to help identify the issue:
Rebuilding the carb with dropping in smaller jets is on my To-Do list but before I get to that, could it be something else? Would it be the cause of improperly gapped plugs? Bad Ignition wires? bad blaster coil? Something internally with the carb? Stuck valves? Or is it something else?
I realize you can't play mechanic over the internet very easily but if you have been there and experienced this issue, I would love to hear about it.
Thank you.
- Engine is a 289 bored .20 over
- Ford Racing Cam (Not sure of the specs)
- Headers
- Flowmaster Exhaust
- Edelbrock RPM Intake
- MSD 6A Ignition Box
- MSD Blaster Coil
- Timing is set to 16 BTDC
- Holley 650 CFM Double Pumper Carburator
Thank you.
