Depends where the feed wire for coil is coming from. If it is using the original wiring there is already a resistor wire in the circuit and the ballast will really cut down voltage to coil. If the feed wire is direct 12 volts you probably neeed the ballast resistor check the feed wire to coil with the key on and it should be less than 12 volts. 8-9 gary
