I'm almost ready to weld in my shock tower reinforcements and I need your advice. I stripped almost the entire shock towers down to bare metal and I have a can of weld through primer for the backsides of the new metal and the areas of the towers that will be welded. My question is this; is it necessary to spray the weld through primer on the areas of the shock towers that will be covered by the new metal, or am I better off using an epoxy primer there and the weld through only where the welds will be made? I want to make sure I have proper rust protection behind the new reinforcements. Thanks in advance.
If you can, I would just use the weld through primer where it needs to be and a little bit outside of that area, and epoxy or a chassis paint everywhere else. I dont think I would go nuts about it, but the heat can do a number on any paint or primer behind it anyway and thats why I would use a heavy coat of weld through in the general area of the heat.
Heavy coat, got it. Also, to any other amateurs thinking of fabricating their own reinforcements for the shock towers, it's a P in the A! I'm not a fabricator and I don't have fancy tools (plasma cutter, torch, etc...), so this project has absorbed a lot of time and lead to SEVERE frustration. If I had to do it again I would buy one of the available kits with the pre-formed pieces, even if they do require some massaging. I've been relying on my angle grinder, propane torch, BFH, and HOPE! But hey, still getting me closer to the goal...
This is what I'm going to do... I'll tape off 1/2" around the edges of all the reinforcements (the backsides) and spray a thick coat of epoxy on all the bare metal still showing. Then I'll remove the tape and spray a few light coats of weld through primer on the remaining exposed metal. The same will go for the shock towers; I'll tape off where the weld beads will be, spray everything else in epoxy, remove tape, spray weld through where the tape was, and then scrape off a small amount of weld through directly where the bead will be layed.
I want to make sure I do this correctly, so it doesn't have to be re-done in a few years. Does anyone see a problem with this method?
Thanks in advance.
I would use weld-through paint where you need to do this. It's the copper-looking paint here:
Thanks for your input. And that's exactly what I'm gonna do; use weld through just on the edges and I picked up some VHT chassis paint for elsewhere. I'll try to post some pics this week of my progress and homemade gussets to see what you fellas think.
