1 - 10 of 10 Posts
1964 1/2 Convertible - 260 V8 C4 Automatic, Power Top, Console, 4 Wheel Drums
Howdy all.
I have a replacement NAPA battery in my 64.5 Mustang, but I think I have one with the battery terminals reversed.
I believe that the positive terminal needs to be on the fender side, and the negative needs to be on the side closer to the engine.
Has anyone found a good source for a flat top battery that will be configured like this?
This photo is the way it should be I think... (that is a fake cover in the pic)
http://www.jasonzimberoff.com/mustang/images/IMG_4977.JPG
The one I have now has the wire from the solenoid going to the post on the right.
Thanks!
-Zim
(actually Slim Jr now)
Most vintage Mustangs use 24F battery. This is a very common battery stocked by most
places that have car parts! I'm surprized NAPA sold you the wrong one!!
oops
I found several at different auto parts stores that had the right post configuration, but they all had the hold down lip in the wrong location. On the way home I stopped at Wal-Mart to get something else, and decided to check out the batteries...And there it was... both the posts and hold down were correct.
I had to use a dremel to open up the holes a bit on the fake cover , but then it all went together perfect
get a battery for a 95 to 00 ford contour. it is a reverse terminal battery and has worked well in my fathers 66 since we had a spare around. you can even get the battery at wal-mart. as for the size it is the same as an optima redtop 34R. fits great with the battery tie down adaptor set you can get from Mustangs Unlimited.
For what it's worth, I couldn't find a 24 anywhere in Wilmington, Delaware. It was really sort of silly. I ended up with an Interstate Batteries 85 I think, from my local Firestone place - the only one that fit, had the polarity right and had the lip for the factory 65 hold-down. That was the third battery I bought - I got one at Pep Boys and then one at NAPA before I settled on thisone. It was to the point where I was physically measuring the battery to see if it would fit, rather than going with a particular number.
1 - 10 of 10 Posts
