Lifting by the carb mounting is plenty strong enough and if it disturbs your intake gaskets, then they weren't done correctly. Lifting by the 4 corners is fine, but I find I have a lot more flexibility lifting by the carb base.
Depends on if I'm pulling or leaving the trans.Another question guys- do you like having the car up on jack stands so you can get at the transmission cross member?
I used the Harbor Freight 3/4 ton leveler, the screw adjuster did bind until I loosened the bolts and adjusted the brackets on the ends. Greased it and it worked fine. It would be nice if everything was perfect out of the box, but while working on my Mustang I haven't found many new parts that didn't need tweaked.If youre looking at load levelers I do NOT recommend the harbor freight one. It's a POS. I got so mad at the hunk of garbage I threw it out into the yard. My buddy says "That's what you get trying to put a 10k plus motor in with a Chinese leveler."
I actually Jack the rear end of the car up high and put on Jack stands so it makes an easier angle up front for pulling out the engine.Another question guys- do you like having the car up on jack stands so you can get at the transmission cross member?
