Best engine lifting method
4343 Views 21 Replies 16 Participants Last post by  subpar63
I'm wondering which method is better and safer lifting an engine (almost fully dressed). Is it using the 4 point method connecting to intake mounting bolts or the lifting plate mounted to the carb mounting bolts? My intake is already on but my carb has not been installed. I may be too much of a worry wort but I'm leary of that much weight being held up with bolts threaded into aluminum plus I really don't want to diturbed the intake mounting bolts that have altready been torqued. Am I stressing for nothing???
21 - 22 of 22 Posts
The picture is many pulls ago but I always pull the motor and trans together because it's easier on my back. It's also more comforting to know you have the engine and trans in proper alignment imo. I like to use the head bolts.
785867
See less See more
Reactions: 1
3
Carb plate with toploader attached - no issues.
Automotive tire Motor vehicle Automotive design Hood Automotive exterior
Automotive tire Tire Motor vehicle Automotive design Flooring
Tire Automotive tire Hood Vehicle Wheel
See less See more
Reactions: 1
21 - 22 of 22 Posts
