1 - 19 of 19 Posts
My painter has this stuff:
Liquid Bottle Solution Fluid Ingredient
I used it to remove the windshield bedding compound. Also used it to remove any of that 3M strip caulk. This stuff is awesome. It removes any and all adhesive. Use it sparingly, $75.00 for that bottle.
Ouch!
I use some kerosene or WD-40. Maybe $7.50.
Reactions: FrankieThe69Kid
3M has an adhesive cleaner that's good. Also, Acetone can be used, dependent, on the surface material.
‘69 Cougar convertible resto mod
Denatured alcohol is also a good adhesive remover. Does a great job on pine tree sap too even after it’s gotten hard.
Brake cleaner.
To the OP: 3M has several adhesive removers. I learned (too late) that some are more paint-friendly than others. It definitely removed the adhesive.
The term is use too....... yeah, I still have a can of the original but the new stuff, waterbased, and I don't think it could remove scotch tape residue!
I swear by 3M adhesive cleaner.
PPG DX330 is another good one. Very paint-safe.
Discussion Starter · #11 ·
DX330 is also good. The Auto Tech stuff is good on any surface. Didn't effect the paint at all. That LMR price is great.
Mach1 Driver beat me to it. LMR seems to have the best price online for the stuff. I use to get it from a plexiglass vendor locally, but they stopped carrying it. Its the best stuff I’ve used to clean plexiglass surfaces and stubborn sticky adhesive residue. Other than the smell, the stuff is great.
Discussion Starter · #16 ·
I kind of like the smell.😄
Most of the "paint-safe" removers are kerosene-based. Acetone, lacquer thinner, and denatured alcohol will eat paint.
Alcohol can be used on a factory paint job. Anything else, other than bare metal, you'll be sorry.
I use kerosene.
1 - 19 of 19 Posts
