For the answer, you need only look at your VMF name! OH!! I thought you meant the bird!!
If it didn't discolor the paint, you might try a rubbing compound. I'd suggest you head to your local Auto Body Supply store - they can probably give you exactly what you need.
Good Luck!
I've used the clay bar (Mothers/Meguiars brands--it's now available at Walmart) for my deep marks and it seems to doo the trick! I would hope the damage isn't too deep that a clay wouldn't fix it and the trick is to keep the surface wet (the kit I have came with the cleaning spray) and apply gentle pressure. Good luck!
