1 - 13 of 13 Posts
So I perform an oil and filter change on my 302 and everything is going fine.
When it is all done and I am happy I start the engine. I immediately notice the oil pressure gauge is showing no oil pressure and I shut off the engine.
I check everything over and it all checks out. I even unscrew the oil filter and double-check it is all ok. Everything looks fine.
It turns out the oil pressure sender decided to stop working at the same time as my oil change. I just happened to have a spare one and I fitted it and the gauge now works as expected.
I like to know why things stop working, so I used a cutting disc to cut the sender can open. It was corroded up inside really badly. So it was going bad for quite some time.
So not the end of the world, but a bit scary when immediately after an oil change, the gauge is showing no oil pressure.
And I am not happy about the sender failing as it only lasted 50 years. I am going to write a letter to Ford about this. Are things not made to last anymore?
Jeremy.
Sometimes a bit of crud works its way into the sending unit orifice. Thats all it takes for a zero reading.
1. That's the kind of bizarre coincidence that ages you prematurely.
2. No, they don't make them like that anymore.
Just an FYI, Unless you are going at 5,000-6,000 RPMs at the time, As long as the engine physically has oil in it...and it loses oil pressure. Absolutely nothing will happen. The engine is more than designed to take Oil Pressure loss at normal RPMs... just the same as if you lost your oil pump or if you broke your oil pump rod to the distributor.
:eek:)
Tony K.
Jeremy.
Hey, I recently replaced my 50 year old starter relay just because. It was starting to look old though!
Same sort of thing will corrode a fuel tank. Moisture accumulates on the insides of things... that's just nature. It'll stick to the inside walls of whatever container it's in. It's heavier than anything in the petroleum family so, once it runs down the walls, it settles on the bottom of whatever it's in... fuel tank, oil pan, oil sender, gas filter... and if it's metal, it'll corrode it.
Change your oil every spring after winter storage, and fuel stabilizer is a good thing.
I had the same problem, the old relay worked fine, looked bad. I masked it off, gently glass-beaded the bracket, then painted the steel to look like cad plating. It's still on the car, years later.
Jeremy.
I would demand a refund of the full price of the car when new, including options! Have your Lawyer draw up a letter on his letterhead, don't let the "MAN" get away with it!!!
Jeremy,
On the bright side, it happened in your garage while you had a spare on the shelf.
Having it give you a false zero psi reading on the road could really ruin a weekend.
You sit on the side or the road waiting for a tow home or to the shop, wondering what the internals look like, fearing the worst.
Then stew a few days til you have the time to get to diagnose the issue.
Yah, be bit of a coincidence, but a gift horse from my vantage point.
Tell Henry hello and thank him as well!!!
Discussion Starter · #11 · (Edited)
Since using the car with the new oil pressure sender, I am noticing that I am getting a higher oil pressure reading on the gauge than before. Only slightly more, but enough to notice.
They are similar to a fuel level sender with a variable resistor made from windings of resistance wire with a wiper going across it. And aftermarket fuel level senders can be a bit hit or miss with how good they are. The replacement sender I had is aftermarket so I think I will buy a genuine Ford one.
i bet theres nothing wrong with the sender
soak in in kerosene or acetone over night shake it around and blow out the hole and soak it again
mines been going 50 yrs. Did this about 5 times since it was new, we are the original owners of the engine
also did it for countless friends all have the sender still working
Are you saying you didn't have oil pressure immediately like within 30 seconds or less you turned off the engine?
1 - 13 of 13 Posts
