Hey all. I'm having a little trouble figuring out how to approach the problem in the photo. It's behind the headlight bucket area so it's difficult to get at. Any suggestions? Larger version is in my flickr gallery
http://farm3.static.flickr.com/2123/2055204696_34b7d13052.jpg
Are you not able to remove the headlight bucket?
To me thats just the flange area on the front fender,If you remove the fender and the bucket you should be able from the backside to get to it and tap it out a little with a rod or dowel. I'm not familiar with a 65-66 front fender though. I am giving reference from experience with a 67-68 and 69-70 where you definitly can get to that area.
Anopther way is to spot weld a tab on the indented part and pull it out. Or you could hammer it into the general shape (so the lines line up) and then weld a bead onto the low spots and grind it off.
Gone but never forgetten
That's exactly what we did with my daughter's '69 fender, that had a good 1/4" gap at one corner (a really weird former "repair" from the PO of the fender and the I'm sure the reason he was selling the "excellent fender" on eBay). We gradually built up the corner with a welder and ground it back into shape. It's probably the strongest part of her entire car now, and totally invisible, once painted *LOL*.
