I have found a trans and I am not sure what it is out of. HERE ARE THE NUMBERS OFF OF IT 13-52-065-907 ON THE SIDE CASE 13-51-066-904 ON THE TAIL SHAFT 13-51-097-901 ON THE TOP 2EN11868 ON THE SIDE Any help would be appreciated.
Sorry, but those numbers don't mean anything.
The transmission should have a tag riveted to the side of it. It will have a code like HEHxxx or RUGxxx.
Give us that code and we can tell you what it is from.
Just some guy
In later model Borg Warner land "1352-065" means a T5 5 speed trans from a 1984 Mustang or Capri V8 car.
Is the trans you are looking at cast iron or aluminum? If cast iron, then my translation doesn't apply. You'll need to talk to somebody that knows about "side loader" trannys. (IE-not me) ::
