1 - 2 of 2 Posts
Hi Guys,
I'm running a 70 B302 oil cooler set-up in my 65 and developed a pretty good leak from the seal behined the large bolt holding the bypass spring in the adaptor housing. I tried a nylon oil pan bolt-type gasket with hi-temp thread sealer, but it didn't work. This looks like it might be a special gasket as the flange of the bolt is pretty wide. Before I try to make a gasket, does anyone have a source for these.
I have NOS oil cooler adapter gaskets, also NOS bolt gaskets,NOS bolts as well as NOS block adapters. I also have NOS oil filter adapters. Not sure which part you will need???
1 - 2 of 2 Posts
