I may be wrong, but I think this was discussed a while back. Not sure though. Try a search. Good luck.
http://albums.photopoint.com/j/View?u=1617612&a=12349055&p=45163239&Sequence=0&res=high.jpg
[color:blue]1969 Mach 1-in restoration</font color=blue>
[color:green]I got my stang on April Fools day. I wonder if that means something....</font color=green>
I've always heard that '69 stripes are a booger!! I remember reading the ones they put on one of the prototypes were actually put on crooked.
1966 GT Convertible (see it at:http://www.geocities.com/tbeamguard/66GT.html)
1969 Sportsroof (which is For Sale, by the way)
Dave,
Although involved, it is not all that difficult. I like to make several measurement points and then use some 1/4 inch 3M Fine Line low tack masking tape to stretch a nice straight guide line along the length of the car. I double check by sighting down the car from rear to make sure the guide line is not lopsided.
Using lukewarm water with a small amount of liquid dishwashing soap (a couple of teaspoons), I sponge on a liberal amount to the area to be striped. I then position the stripe, using the guide line tape as a reference point. Using a nylon squeegie (bondo appliers you can buy at Walmart, Pep Boys, etc), I carefully work out any bubbles from the center of the stripe out to the edge, using a towel to wipe off the excess. I let the stripe airdry for a few hours before pulling off the protective backing, making sure you pull the backing almost parallel with the stripe itself so as not to pull it off. You can use a hair dryer to speed up the drying process.
In the future, try not to get wax on the reflective stripe as it tends to lift the edges eventually....
randy
http://www.bossman-motorsports.com/boss2.jpg
http://www.bossman-motorsports.com/bossbanner2.gif
I really like the looks of your car. The stripes you put on I assume are the decal type you are referring to. How about the hood - are they the same? The soap doesn't interfere with the adhesion?
Thanks,
Tom
Not sure what year/style your referring to. I found the 70 a little more difficult and involved but pick a cool day and put the car up on level stands or a lift (I like to sight down the side to line up the long stripes.
As already mentioned water with a very little soap, mask the stirpes into place along the top edge and start with the big stripe first.
Make sure you get a chance to look at some original cars (if you care) first beacuse the stripes often had little oddities as how and where they were place. Example 70 stirpes varied a bit between the Dearborn and NJ plant installation
Jeff Speegle
MCA Shelby Gold Card
http://www.geocities.com/MotorCity/6473
Mustang & Shelby research, documentation
http://albums.photopoint.com/j/View?u=1609818&a=12284202&p=44925357&Sequence=7&res=high.jpg
Discussion Starter · #7 ·
Thanks guys for all the response. It's a 70. Wish me luck. I'll post a picture when it's done.
Dave
