What is the real benefit of these? It looks like the Russell's are about $80 for the front. I will be using the non-power SSBC kit.
You get a bit more hydraulic pressure to the calipers because the braided lines won't give like a rubber line does. By give I mean swell when pressure is applied.
I purchased these but have yet to install them. They do not match up to the hole in the bracket. The hose has a D shaped pilot and my brackets have a 12 pointed hole. The same problem with the rear hose. I have not spent much time working on how to solve this, but I guess the simplest method will be having someone weld something to the brackets with the correctly shaped hole.
I put Baer brakes on mine and the lines that came with the kit fit into the stock brackets. Might want to check with them.
Your brakes will brake better, with less risk of breaking.
Plus they look cooler.
I know they made a huge difference on my old Katana 1100.
