I have researched the forum, but still have a couple questions. Neither brake light works, the right blinker works, but not the left (checked both bulbs). Is it the turn signal cam that I should replace, or is there another culprit I should be looking for. Thanks!
Replace the entire turn signal unit. That is the normal problem area.
I do believe the flasher wiring still passes thru the turn signal switch.
Right one works, left one still does not.
You can chase the wiring to confirm it is good but my bet is still on the turn signal switch. All the wiring to the brake/turn/flashers go thru that switch.
