A few weeks ago I posted the difficulty I am having with the Stainless Steel brake lines I puchased from "Right Stuff" detailing. I suspect that SS is so much harder than carbon steel and therefore requires more torque to seal than can be applied while using the original calipers, distribution block and proportioning valve. After weeks of trying to seat the SS lines, I cannot get them to stop leaking. They leak at ALL junctions, not just one or two.
So, have other folks encountered the same issue using SS lines?
I think it's time I give up on SS and go back to carbon steel lines. If I use DOT5 fluid (which I am), should that minimize rusting of the carbon steel lines?
Can anyone speak to using regular steel lines and how quickly they start to rust and look bad?
