hello
i am in the process of doing a front disc brake conv. on my 65 vert. i have two questions. first is regarding the brake pedal and master cyl. pushrod. i am using the scott drake power booster and master cylinder kit. i have it all mounted BUT i am having a very hard time with where everything mounts on the pedal. the brake pedal has the round bit where the brakelight switch etc. mounts. after i have put everything on in the order it came off i cant use the outboard nylon washer and get the clevis pin in. if i skip the outboard nylon washer i CAN get the pin in from below but it just falls back out. i cant figure out WHY the assembly now is wider so i cant use the last nylon washer? working from the brake pedal out it appears that it should be assembled in the following sequence. nylon washer, first side of brake-light switch, the power booster pushrod complete with its nylon bushing inserted, second side of brake-light switch, second nylon washer and finally the clevis pin. but as mentioned if i use that second nylon washer it covers the hole and i cant insert the pin....
second question is that i am thinking about undoing the clamp that holds the steering column in place so i can possibly lower the column a bit to get a little more room for my fat hands. there are 2 nuts on threads that hold it in place. when i turn one of the nuts the stud or bolt or whatever it is turns as well. i cant get my hand up there to feel what it is??? anybody know how that is put together? i dont want to undo it if i cant get things threaded back together. hope this all makes sense.
thanks
kent
thanks
kent
