I am having a stange problem on the 68GT (disk front, drum rear). My brakes have excessive pedal play before they grip. I have checked everything, I think. Master cylinder Booster holds a vac, so does the can, no leaks in fittings or tubing. Booster lever adjustment OK. Did a gravity bleed all around so no air. All calipers and cylinders OK. Thoughts? Sometimes when you rev the engine you feel a little pedal drop like she is short of vacuum. I am pulling my hair out.
Signed, Kojak
How about the pushrod? Does it feel like it's engaging the master cylinder immediately, or is that where the slop is?
I assume it's an original power brake car? You know the power brake 68s had a different pedal setup than the manual brake cars, right?
Have you tried adjusting the rear drums? The are what will define your pedal feel.
Try this; In park or whatever, set your ebrake as hard as you can. Press on the brake pedal. If the play is gone, you have found your problem......
To add to Hemikiller's post....
If the rear drums have been turned (oversize) past the recommended limit you won't have a solid pedal.
And while you're at it, unless you already have, you might as well replace the (rubber) front brake hoses.
I have a prob with my kids' '65 that the firewall flexes when braking. Watch the MC/booster while an assistant applies the brakes, and see if it moves. I'll be putting some kind of brace between the firewall and the shock tower one of these days.
7
