I have a 67 GT with front disks. The pads, rear shoes, master cylinder, booster and all lines are new. I seem to have good vacuum to the booster. The system is bled and I have excellent peddle pressure. My issue is stopping, they work, but not very well. The proportioning valve is original, could this be the problem?
when you say they work, just not well, what exactly is the issue? Hard pedal? Are the pads okay, or are they glazed/contaminated?
Well, you mentioned eveything is new...EXCEPT the calipers and the rear wheel cylinders.
The Kelsey Hayes calipers are a little prone to having stuck pistons. Check into that.
Do you have a aluminum intake? They have a vacuum booster valve for this. This will help with your brakes. LOL
TCT
ALso,
There are high pressure lines going into your calipers and they deteriorate over time. They are like your arteries and get smaller and smaller over time. I have replaced these to correct bad braking. :: Again, LOL.
TCT
If you replace the hoses, use stainless steel ones!
Just because the booster is new does not mean that it works. I went through three of them before I got one that worked.
Symptoms: nice firm pedal, no stopping power.
