861 - 880 of 962 Posts
Discussion Starter #861
You let her drive it didn't you?
Not yet John. I have a strong feeling she won't be too impressed with the strong clutch and manual steering ;)😂
Wait...you mean you aren't painting it... :unsure: ?
I don't mind having the shop painter do it. I have never sprayed water base so not interested in spraying it on my car. If I had been painting it at home, I'd be definitely using solvent base but in the city they are mandated to use waterborne.
Discussion Starter #862
Finished trimming the carpet today, sprayed a couple coats of epoxy on my splash guards and re-checked my clutch adjustment. Also got the guide coat on for final blocking, starting tomorrow. I have about 7/8" of pedal travel before I can feel the T.O. bearing, exactly 1/8" adjustment at the lower clutch rod. With all the talk about clutches, I had to double check ;).
Btw, I have been re-thinking my paint job. Sitting here tonight, looking at this car and thinking about all the hours I've put in to it. I'll be painting the car MYSELF.
1968 coupe, 1968 vert, 1966 coupe
Will you be painting it like that? Or taking the hood, trunk lid and fenders off?
Looks good Brian
Lot's of fun putting the staples through those splash gaurds!
Discussion Starter #871
@Mustmatt, you got me thinking about the splash guards so I had to try one. I took one of the staples and matched it up with a drill bit. Next I cut a little piece of sheet metal and drilled 2 hole to match up with the staple. I used a few pieces of masking tape to position 2 pieces of rubber on the guard. Then with the template I drilled the first set of holes. Pushed the staple in and with a pair of needle nose pliers I squeezed the ends enough to hold the staple in. Then with a body hammer and piece of rail for a backer, I tapped them down. Must say it went pretty smoothly. Then the mosquito's darn near ate me alive so had to give it up after finishing the first one. 😂
Great, here’s one more thing weighing on my mind. I can’t recall if I checked after my car bodywork and paint was done to ensure this was done. Thanks, Brian...
Discussion Starter #874
I let it go too Russ. Since mine are re-pros I'll fit them before I paint the fenders. My originals must have been rotten, no trace of them. We should be hitching it up tomorrow and heading to Halifax. As you say, "$hits about to get real" 🤣
