1 - 10 of 10 Posts
Hi. I was having some weird timing issues with my 351w with a b303 cam in it. I pulled the cap off the distributor and there was a big chunk of magnet flying around, the rotor wiggles, and the vacuum advance doesn't do anything.
The trouble is as it is a roller cam it needs a steel gear (I think .531?), however off the shelf distributors for 351s use cast-iron gears.
The question is, what distributor would yall recommend? Or should I find a used one / get a rebuild kit and just fix the broken parts leaving my working steel gear and shaft intact?
Thank you!
I'm not a 351 distributor expert, but can't you just drive out the pin and press the gear off of your existing distributor and then press it on to a new one?
You can use a Melonized gear. Check MSD. I bought a MSD Melonized gear from AutoZone a few years back for my GT40P swap. It was $29. I upgraded to a Duraspark system and bought a brand new distributor for around $70. While you can just replace the broken parts in the long run it may be more cost effective to buy a brand new one from Rockauto or local AP store
Discussion Starter · #5 ·
You can always swap to a '93 5.8 distributor with a steel gear and run a remote TFI module.....
I think I could just swap my steel gear onto a new distributor? I found these two, they are available locally but I can't tell the difference. I think they'll connect to my duraspark system as a drop in replacement. I'd rather not mess around with an entirely new brand of distributor unless there's really a benefit.
or
Discussion Starter · #7 · (Edited)
The first distributor you reference is for a 351M/400. Bear in mind that you can simply pop off the old gear and stick on a new one. The new gear needs to be precisely placed with the hole in the gear offset 90* to the original, a new hole drilled in the shaft and new roll pin inserted.
https://performanceparts.ford.com/download/pdfs/DistributorGearInstallation.pdf
The ones I mentioned also have different plug connectors. I think this one looks perfect:
CARQUEST Ignition Distributor with Cap and Rotor - New
Thank you for that PDF. Should/could I just use the original shaft, swap the rest of the parts and not even have to pull it out of the motor?
Why not simply get a new pick-up module and rotor (and figure out if your vacuum advance diaphragm is holed or just disconnected)?
772391
Discussion Starter · #9 ·
I'm not sure what is broken about my distributor or what that metal piece fell off of. The vacuum canister holds a vacuum but it doesn't seem to do anything when I put a few lbs of vacuum on it. I guess id rather replace the entire housing and everything inside if I could. The rotor has a ton of play in it.
Discussion Starter · #10 ·
Thank you. I ended up just buying a new pickup and cleaning up the inside of the distributor. Instead of falling of at 4k, the engine revs up to 6,000 now. Appreciate your time!
1 - 10 of 10 Posts
