66 Mustang
So, installed these moulding clip heathens today. What a pita!!! Anyhow, one of the pins on the rear window decided to take a detour off the car when I was knocking them on.
I read you can put a small screw in place of it. My question is, do i have to put it exactly where the other pin was? Or can I go right next to it? If it needs to go exactly where the other one was, should I just blast it through with a punch?
749773
Right where it was should be fine, easier to locate its opposite if needed.
66 Mustang
Should I just whack it thru with a punch? Or can I just set it about 1/4" off to the side?
Check your trim. If it doesn't have a dedicated slot for the retainer, then go ahead and put your screw either side of the original location.
The assembly manuals allow lateral positioning of the pins within +/- a quarter of an inch. It's the depth and height from the flange that must be exacting. Note you may be able to use the original holes if they're still there. Screws for replacement duty are Pan Phillips Sheet Metal 6x1/2, and I used stainless steel ones to replace mine that were missing.
I replaced one offset a bit without issue.
66 Mustang
Thanks fellas!
