Thought I would give my VMF friends first dibs before posting elsewhere. I won't be needing these. Prices and pictures are included, just add shipping to your zip. Prices are listed below what they have actually sold on other locations but also open to negotiation - just be fair. I can provide additional close up pictures of any item you are interested in, contact me through this post or PM me with your e-mail for pictures.
386056-S2 carb air cleaner studs pk of 4 $10
C2DZ-10718-C battery hold down clamp 2 available 65-66 $15 ea
C2RZ-15A700-A lamp kit, engine or trunk $45
C3DZ-3020-A front suspension bumper pk of 2 $10
C30Z-16228-B emblem v289 (C30B16C144A) 3 available $20 ea
C4AZ-2004-A M/C repair kit $35
C4AZ-7A247-C switch neutral safety 65-67 $45
C5AZ-12370-R (DD-190) Diaphragm dist vacuum $125
C5AZ-9155B fuel filter $10
C5ZZ-1130-W red wheel hub center caps qty 3 65-67 $55 ea
C5ZZ-1012-B Chrome wheel lug nuts set of 5 $20
C5ZZ-13217-C seal, front parking assy lamp to valance pk of 2 $10
C5ZZ-14526-A relay Fog lamps 2 available $20 ea
C5ZZ-15510-A gasket, backup lens 65-70 4 in the box $20
C5ZZ-16228-B emblem, High Performance backplate K-code $40
C5ZZ-16228-D running horse tri-bar driver side 65-68 $25
C5ZZ-16229-B running horse tri-bar pass side 65-68 $25
C5ZZ-17A553-D 2-speed switch (C4ZB-17A553D) $50
C5ZZ-2282A brake hose $10
C5ZZ-6543603-B trunk lock housing (F1539-01) 65-66 with pad $20
C5ZZ-7262-A 65-68 shifter bezel – 4 speed (C4ZB-7262-B) $300
C6DZ-10884-B(SW-552)temp sending unit (motorcraft) 65-77 $15
C8GY-5443505-A trunk lock cylinder with keys $40
C8TZ-9722454-A door handle button kit 2 sets available $45 ea
C9ZZ-7591-A Spring, clutch return 69-73 $10
D0AZ-18599-A manifold elbow 390, 351C 69-73 $30
D0ZZ-16C896-A chrome hood lock/pins kit 69-73 w/ hardware $75
(missing one hood screw)
D1AZ-14413-A glove box light kit 71-74 ford, 73-78 Torino $20
D3TZ-13853-A relay, horn 65-69 $45
D3ZZ-2251-A wheel cylinder $10
D9BZ-7052-A oil seal, transmission, ‘70s and ‘80s $10
DOZZ-17A553-B 2 speed wiper switch (D0ZB-17A553-A) $100
Have not seen the ’70 model reproduced
F3ZZ-9030-A pop open gas cap (C8ZZ-9030-CF) $150
FILCO 3360LC ignition switch with keys $10
