1 - 20 of 22 Posts
I didn't install a bung but I did install a 1/8" pipe thread plug. Works great!
Oh yeah, "No bung for me" (soup nazi voice) either! There was enough steel in the center section to tap the threads.
Great idea , get right on it .
Oops , already have a drain on the early 9" in my stang .
Does make it easier to change on a regular basis .
'just making surei am understanding correctly...
You guys are putting a drain plug in the steel housing or the cast iron carrier (pumpkin)?
Exactly what are you using for the plug? I wish I had thought of this when I had my diff apart last December. It sounds like a great idea.
Use a generic pipe plug.
1/8" brass pipe plug (square head type) in the steel section, not the pumpkin.
There is quite a bit of gear oil that is trapped in the housing when you remove the pumpkin. This drain plug location allows that fluid to drain....
I had a bottom drain plug installed when my 9" was rebuilt. The rebuilder even welded a small shield to guard road debris from hitting the drain bolt. It definitely make servicing the rear much easier.
I have seen it done both ways. My preference was to use the weld-in bung...much stronger and you don't have to worry about a jack doing any damage to a pipe plug...which can happen when putting a jack under the housing. The rear of the car is a lot of weight to put on the threads in steel housing. Just my 2 cents worth.
In the early years, Ford installed drain plugs in the rear end housings from the factory. 1957 was the first year for the 9-inch rear end, and all those rear end housings came from the factory with a 3/8" pipe plug installed in the bottom (sump) of the housing.
Many '58 and '59 9-inch models had them too but after that, Ford pretty much quit installing them for whatever reason.
'57 Ford 9-inch station wagon large bearing housing on left, '59 Fairlane 9-inch small bearing housing in middle, '60 T-Bird 9-inch large bearing housing on right"
http://ultrastang.com/Images/Scanned/Rears/20-s.jpg
Dan
I don't have on in mine but from my buddy that build diff's. He replied just like Steve. and make it as level as possible for better draining.
oooo aluminum chunk
Discussion Starter · #18 ·
Henry,
I saw your pic and wanted to know how much is hanging below the rear end? I have purchase a moroso bung whihc looks like this:
http://static.summitracing.com/global/images/prod/large/mor-23970_w.jpg
It looks long and thought about removing ~ 1/4" so it would remove the most amount of oil and still keep it somewhat flush with the bottom of the pan ~ It appears that it would hang down about 1/4" then and still be about 1/4" internally higher within the pumpkin. I hope I said that correctly and clearly.
Also, I don't own a hex head that large and thought about welding up a couple of bolts end to end in order to open close it. Sound OK?
1 - 20 of 22 Posts
