From a Previous post.......1972 Mustang Convertible Re: 71-73 Buzzerrrrrrrrr
My door buzzer comes on when I open the drivers door and the keys aren't in the ignition and no other accessories are on.
From what I have gathered from my previous post it should only come on when I put the keys in the ignition. Now I got this car in pieces and the electrical was in one box.You know grab a plug and see if it fits here or there when your putting it back together.
I have a electrical manual for this car and year but it isn't much help. What I want to know is could the plugends on the wire harness plug into more than one relay or extension or do they plug into only the relay that there ment for?
I'm not sure but at the tip of the key inside the ignition switch might be bad.
In the old days we would gring off the end of the key to keep the buzzer quiet. Your switch might be buggered up.
That's because your ignition switch thinks the key is actually in there even if it's not !!!
